Есть код, раньше работал, но после переустановки excel напрочь отказывается работать... Пишет ошибку user defined type not defined и выделяет код [vba]
rx As New RegExp
вот собственно сам код... [vba]
Private Sub Worksheet_Change(ByVal Target As Range) Application.ScreenUpdating = False Dim MyConn As String, ContrInf As String Dim fio As String, summ As String, rashod As String, MinPlatezh As String, limit As String, sotr As String, fininst As String, ostatok As String, Cnt As Integer Dim fin As String, rozd As String, pasp As String, propiska As String, fakt As String, ssylka As String Dim nach_d As String, nach_m As String, nach_y As String, kon_d As String, kon_m As String, kon_y As String, dopki As String Dim rx As New RegExp, Matches As MatchCollection, Match As Match
rx.MultiLine = True rx.Global = True rx.IgnoreCase = True Application.EnableEvents = False If Target.Cells.Count = 1 Then If Not Application.Intersect(Target, Range("cards")) Is Nothing Then ' Target.Value = Mid(Target.Value, 2, 16) rx.Pattern = "\d{16}" Set Matches = rx.Execute(Target.Value) If Matches.Count > 0 Then Target.Value = Matches(0).Value ContrInf = ContractInfo(Target.Value) rx.Pattern = Target.Value Set Matches = rx.Execute(ContrInf) If Matches.Count > 0 Then ParseResponse ContrInf, fio, rashod, MinPlatezh, dopki, limit, ostatok, fin, rozd, pasp, propiska, fakt, ssylka Cnt = Target.Row - Range("cards").Row + 1
Cells(Target.Row, 1).Value = Cnt Cells(Target.Row, 3).Value = fio Cells(Target.Row, 5).Value = rashod Cells(Target.Row, 4).Value = MinPlatezh Cells(Target.Row, 7).Value = dopki Cells(Target.Row, 8).Value = limit Cells(Target.Row, 10).Value = ostatok Cells(Target.Row, 11).Value = fin Cells(Target.Row, 12).Value = rozd Cells(Target.Row, 13).Value = pasp Cells(Target.Row, 14).Value = propiska Cells(Target.Row, 15).Value = fakt Cells(Target.Row, 27).Value = ssylka Else Cells(Target.Row, 3).Value = "нет данных" Target.Activate End If End If End If End If Application.EnableEvents = True Application.ScreenUpdating = True End Sub
Помогите пожалуйста, гуру экселя...
rx As New RegExp
