= Мир MS Excel/Из VBA в SQL перенос типа данных date - Мир MS Excel
Elhust Дата: Среда, 15.03.2017, 13:42 | Сообщение № 1
Репутация: -1 ±
Dim Conn
Sub test_connALL()
Dim cmd         As ADODB.Command
Dim Conn        As ADODB.Connection
Dim rs          As ADODB.Recordset
Dim lLastrow, i As Long
Dim iCell       As Range
Dim whereID     As Long
Dim FAM, IM, OT   As String
Dim DAT As Date
'On Error GoTo Err
iTimer! = Timer
Set Conn = New ADODB.Connection
If UserForm1.TextBox2.Text = "" And UserForm1.TextBox1.Text = "" Then
UserForm1.Show
Else
'Range("G2:G65536").Clear
lLastrow = Cells(Rows.Count, 5).End(xlUp).Row
i = 1
Conn.ConnectionString = "driver={SQL Server};server=197.76.8.177;uid=" & UserForm1.TextBox1.Text & ";pwd=" & UserForm1.TextBox2.Text & ";database=MainDWH"
Conn.Open
'On Error Resume Next
With ThisWorkbook.Worksheets(2)
For Each iCell In .Range("E2", Cells(lLastrow, 5))
i = i + 1
If Cells(i, 68) <> "" Then GoTo Point
'FAM = iCell
'IM = iCell.Offset(0, 1)
'OT = iCell.Offset(0, 2)
DAT = iCell.Offset(0, 4)
MsgBox DAT
'MsgBox FAM & " " & IM & " " & OT
Set cmd = New ADODB.Command
     With cmd
          .ActiveConnection = Conn
          '.Parameters.Append cmd.CreateParameter("@FAM", adBSTR, adParamInput, Value:=FAM)
          '.Parameters.Append cmd.CreateParameter("@IM", adBSTR, adParamInput, Value:=IM)
          '.Parameters.Append cmd.CreateParameter("@OT", adBSTR, adParamInput, Value:=OT)
          .Parameters.Append cmd.CreateParameter("@DAT", adDate, adParamInput, Value:=DAT)
          .CommandType = adCmdStoredProc
          .CommandText = "port.sp_AfsSOAP_RequestTEST_ALLL"
     Set rs = cmd.Execute()
     Cells(i, 68).CopyFromRecordset rs
     rs.Close
Point:
везде стоит тип данных DATE а в SQL принимает значение
ALTER PROCEDURE [port].[sp_AfsSOAP_RequestTEST_ALLL]
@DAT date
AS
BEGIN
DECLARE @ID nvarchar(20)
SELECT @ID= ANKETA_ID FROM port.Ankets
WHERE  ANKETA_BIRTH_DATE=CONVERT(DATETIME,'@DAT',104)
EXEC port.sp_AfsSOAP_RequestTEST_ID
@ID
END
GO
ANKETA_BIRTH_DATE в этой колонке дата типа DATETIME
пробовал многими способами выдаёт ошибку
Microsoft Visual Basic for Applications
System Error &H80040E21 (-2147217887).
ОК Справка
Heeeelp, guru VBA
Каждый сам выбирает правила игры
Сообщение отредактировал Elhust - Среда, 15.03.2017, 13:43
Dim Conn
Sub test_connALL()
Dim iCell       As Range
Dim whereID     As Long
Dim DAT As Date
'On Error GoTo Err
iTimer! = Timer
UserForm1.Show
Else
i = 1
Conn.Open
i = i + 1
'FAM = iCell
MsgBox DAT
     With cmd
     rs.Close
Point:
@DAT date
AS
BEGIN
@ID
END
GO
ОК Справка
Heeeelp, guru VBA
Автор - Elhust
Дата добавления - 15.03.2017 в 13:42
Elhust Дата: Среда, 15.03.2017, 13:52 | Сообщение № 2
Репутация: -1 ±
это точно ошибка в соответствии с типом данных в этой цепи, но вот какие типы расставить чтобы приходило к верному ( подскажите оптимальное решение
Сообщениеэто точно ошибка в соответствии с типом данных в этой цепи, но вот какие типы расставить чтобы приходило к верному ( подскажите оптимальное решение
Автор - Elhust
Дата добавления - 15.03.2017 в 13:52
devilkurs Дата: Среда, 15.03.2017, 14:11 | Сообщение № 3
Репутация: 43 ±
Excel 2007, 2010
Elhust, В каком виде данные типа datetime в SQL ? Я на в Access сталкивался с тем что в запрос приходилось ложить типа '01/01/2011' (с апострофами)
В данном варианте в запрос падает значение типа 01.01.2011 .
[offtop]SQL знаю очень слабо (((
Сообщение отредактировал devilkurs - Среда, 15.03.2017, 14:13
СообщениеElhust, В каком виде данные типа datetime в SQL ? Я на в Access сталкивался с тем что в запрос приходилось ложить типа '01/01/2011' (с апострофами)
Автор - devilkurs
Дата добавления - 15.03.2017 в 14:11
Elhust Дата: Среда, 15.03.2017, 14:46 | Сообщение № 4
Репутация: -1 ±
devilkurs,дд.мм.гггг на сколько я понимаю так как там стоит тип 104 он отвечает за такую раскладку но точно не помню с минутами или нет у меня пока нет доступа к msdn (
Сообщение отредактировал Elhust - Среда, 15.03.2017, 14:47
Сообщениеdevilkurs,дд.мм.гггг на сколько я понимаю так как там стоит тип 104 он отвечает за такую раскладку но точно не помню с минутами или нет у меня пока нет доступа к msdn (
Автор - Elhust
Дата добавления - 15.03.2017 в 14:46
Elhust Дата: Среда, 15.03.2017, 14:48 | Сообщение № 5
Репутация: -1 ±
devilkurs, но я так понимаю что соль в том что данные SQL не принимает на уровне @DAT если там будет нужный тип то будет работать
Сообщениеdevilkurs, но я так понимаю что соль в том что данные SQL не принимает на уровне @DAT если там будет нужный тип то будет работать
Автор - Elhust
Дата добавления - 15.03.2017 в 14:48
Elhust Дата: Среда, 15.03.2017, 15:07 | Сообщение № 6
Репутация: -1 ±
devilkurs, а нет это Date (гггг-мм-дд) а Datetime (гггг-мм-дд чч:мм:сс.000)
Сообщениеdevilkurs, а нет это Date (гггг-мм-дд) а Datetime (гггг-мм-дд чч:мм:сс.000)
Автор - Elhust
Дата добавления - 15.03.2017 в 15:07
Elhust Дата: Среда, 15.03.2017, 15:20 | Сообщение № 7
Репутация: -1 ±
Тема в том что у меня не доходят данные даже до конвертации описанной в запросе
@DAT date
AS
BEGIN
@ID
END
GO
попробовал с типом данных INT, везде расставил его и в экселе тоже и в параметре , ошибка изменилась как я понял дошло до конвертации так как окно с ошибкой вообще пустое окно !
Сообщение отредактировал Elhust - Среда, 15.03.2017, 15:22
СообщениеТема в том что у меня не доходят данные даже до конвертации описанной в запросе
@DAT date
AS
BEGIN
@ID
END
GO
Автор - Elhust
Дата добавления - 15.03.2017 в 15:20
Elhust Дата: Среда, 15.03.2017, 15:57 | Сообщение № 8
Репутация: -1 ±
Нашел решение )
тут у нас SQL
CREATE PROCEDURE [port].[sp_AfsSOAP_RequestTEST_ALL]
@FAM nvarchar(15),
@IM nvarchar(15),
@OT nvarchar(15),
@DAT date
AS
BEGIN
SELECT @ID = ANKETA_ID FROM port.Ankets
WHERE  ANKETA_FAM=@FAM AND ANKETA_IM=@IM AND ANKETA_OT=@OT AND ANKETA_BIRTH_DATE=@DAT
@ID
END
GO
Dim Conn
Sub test_connALL()
Dim iCell       As Range
Dim whereID     As Long
Dim DAT As Date
'On Error GoTo Err
iTimer! = Timer
UserForm1.Show
Else
i = 1
Conn.Open
i = i + 1
FAM = iCell
     With cmd
          .Parameters.Append cmd.CreateParameter("@DAT", adDBTimeStamp, adParamInput, Value:=DAT)
          .CommandText = "port.sp_AfsSOAP_RequestTEST_ALL"
     rs.Close
Point:
    MsgBox "Время выполнения макроса составило " & _
    Timer - iTimer! & " сек.", vbExclamation, ""
Conn.Close
Set rs = Nothing
Set con = Nothing
Exit Sub
'Err:
'MsgBox ("Проверьте корректность ввода")
СообщениеНашел решение )
тут у нас SQL
@FAM nvarchar(15),
@IM nvarchar(15),
@OT nvarchar(15),
@DAT date
AS
BEGIN
@ID
END
GO
Dim Conn
Sub test_connALL()
Dim iCell       As Range
Dim whereID     As Long
Dim DAT As Date
'On Error GoTo Err
iTimer! = Timer
UserForm1.Show
Else
i = 1
Conn.Open
i = i + 1
FAM = iCell
     With cmd
     rs.Close
Point:
Conn.Close
Set rs = Nothing
Set con = Nothing
Exit Sub
'Err:
Автор - Elhust
Дата добавления - 15.03.2017 в 15:57
