= Мир MS Excel/Возможна ли замена Case на работу с массивом - Мир MS Excel
ant6729 Дата: Среда, 26.07.2017, 21:58 | Сообщение № 1
Репутация: 2 ±
Замечаний: 40% ±
Еще раз добрый вечер.. .
Решил задачу вот таким образом:
Sub dfdfd ()
s = InputBox("")
Select Case s
Case Is = 1
Cells(1, 9).Value = "3:00:36"
Case Is = 2
Cells(1, 9).Value = "1:52:12"
Case Is = 3
Cells(1, 9).Value = "1:25:12"
Case Is = 4
Cells(1, 9).Value = "1:56:24"
Case Is = 5
Cells(1, 9).Value = "2:36:36"
Case Is = 6
Cells(1, 9).Value = "2:25:48"
Case Is = 7
Cells(1, 9).Value = "2:44:24"
Case Is = 8
Cells(1, 9).Value = "2:58:48"
Case Is = 9
Cells(1, 9).Value = "3:27:00"
Case Is = 10
Cells(1, 9).Value = "3:02:24"
Case Is = 11
Cells(1, 9).Value = "0:24:00"
Case Is = 12
Cells(1, 9).Value = "0:34:12"
Case Is = 13
Cells(1, 9).Value = "0:45:00"
Case Is = 14
Cells(1, 9).Value = "2:45:00"
Case Is = 15
Cells(1, 9).Value = "2:06:00"
Case Is = 16
Cells(1, 9).Value = "2:41:24"
Case Is = 17
Case Is = 18
Cells(1, 9).Value = "1:34:12"
Case Is = 19
Cells(1, 9).Value = "1:45:00"
Case Is = 20
Cells(1, 9).Value = "2:18:00"
Case Is = 21
Cells(1, 9).Value = "1:37:48"
Case Is = 22
Case Is = 23
Cells(1, 9).Value = "1:27:36"
Case Is = 24
Cells(1, 9).Value = "0:44:24"
Case Is = 25
Cells(1, 9).Value = "1:18:00"
Case Is = 26
Cells(1, 9).Value = "1:20:24"
Case Is = 27
Cells(1, 9).Value = "2:25:12"
Case Is = 28
Case Is = 29
Cells(1, 9).Value = "0:23:24"
Case Is = 30
Cells(1, 9).Value = "2:04:12"
Case Is = 31
Cells(1, 9).Value = "0:30:00"
Case Is = 32
Cells(1, 9).Value = "1:28:48"
Case Is = 33
Cells(1, 9).Value = "2:08:24"
Case Is = 34
Cells(1, 9).Value = "2:11:24"
Case Is = 35
Cells(1, 9).Value = "3:01:12"
Case Is = 36
Case Is = 37
Cells(1, 9).Value = "1:02:24"
Case Is = 38
Cells(1, 9).Value = "2:49:48"
' и прочее
End Select
У меня подозрения на счет записи всего этого через массив... Вроде, что-то видел в других языках...
Но как...
Можно ли как-то иначе оптимизировать эту длину?
VLOOKUP можно, конечно, но не то...
Есть ли какие-то другие варианты, подскажите, пожалуйста.
Сообщение отредактировал ant6729 - Среда, 26.07.2017, 22:34
СообщениеЕще раз добрый вечер.. .
Sub dfdfd ()
s = InputBox("")
Select Case s
Case Is = 1
Case Is = 2
Case Is = 3
Case Is = 4
Case Is = 5
Case Is = 6
Case Is = 7
Case Is = 8
Case Is = 9
Case Is = 10
Case Is = 11
Case Is = 12
Case Is = 13
Case Is = 14
Case Is = 15
Case Is = 16
Case Is = 17
Case Is = 18
Case Is = 19
Case Is = 20
Case Is = 21
Case Is = 22
Case Is = 23
Case Is = 24
Case Is = 25
Case Is = 26
Case Is = 27
Case Is = 28
Case Is = 29
Case Is = 30
Case Is = 31
Case Is = 32
Case Is = 33
Case Is = 34
Case Is = 35
Case Is = 36
Case Is = 37
Case Is = 38
' и прочее
End Select
Но как...
Автор - ant6729
Дата добавления - 26.07.2017 в 21:58
ant6729 Дата: Среда, 26.07.2017, 22:12 | Сообщение № 2
Репутация: 2 ±
Замечаний: 40% ±
Должно быть что-то вроде)
s = input
time = Array("2:45:00";"1:02:24";"3:01:12")
Cells(1, 9).Value = индекс (s)
.... не знаю
Сообщение отредактировал ant6729 - Среда, 26.07.2017, 22:13
СообщениеДолжно быть что-то вроде)
s = input
.... не знаю
Автор - ant6729
Дата добавления - 26.07.2017 в 22:12
Pelena Дата: Среда, 26.07.2017, 22:52 | Сообщение № 3
Репутация: 4703 ±
что-то вроде
Option Base 1
Public Sub tm()
    Dim time()
    s = InputBox("")
    time = Array("2:45:00", "1:02:24", "3:01:12")
    Cells(1, 9).Value = time(Val(s))
что-то вроде
Option Base 1
Public Sub tm()
    Dim time()
    s = InputBox("")
Дата добавления - 26.07.2017 в 22:52
ant6729 Дата: Среда, 26.07.2017, 22:58 | Сообщение № 4
Репутация: 2 ±
Замечаний: 40% ±
..Круто...!
Спасибо, Pelena!!!
Сообщение..Круто...!
Спасибо, Pelena!!!
Автор - ant6729
Дата добавления - 26.07.2017 в 22:58
KuklP Дата: Четверг, 27.07.2017, 06:11 | Сообщение № 5
Репутация: 486 ±
Чуть сократил:
Public Sub www()
    Cells(1, 9).Value = Choose(InputBox(""), "2:45:00", "1:02:24", "3:01:12")
[/vba] B)
СообщениеЧуть сократил:
Public Sub www()
[/vba] B)
Автор - KuklP
Дата добавления - 27.07.2017 в 06:11
