= Мир MS Excel/Метод Autofill из класса Range завершен неверно - Мир MS Excel
GalinaS Дата: Вторник, 28.02.2023, 11:31 | Сообщение № 1
Помогите, пожалуйста. Записывала макрос именно с помощью записи макроса. При выполнении макрос выдает ошибку Run-time error '1004': Метод Autofill из класса Range завершен неверно. Ругается на строчку Selection.AutoFill Destination:=Range("I2:I9806")
Cells.Select
Selection.Replace What:="0", Replacement:="", LookAt:=xlWhole, _
SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _
ReplaceFormat:=False
Selection.Replace What:="н/с", Replacement:="", LookAt:=xlWhole, _
ActiveWindow.ScrollColumn = 33
ActiveWindow.ScrollColumn = 26
ActiveWindow.SmallScroll Down:=57
ActiveWindow.ScrollRow = 2915
Selection.Replace What:="00.01.1900", Replacement:="", LookAt:=xlWhole, _
ActiveWindow.ScrollRow = 1
Range("AJ7").Select
ActiveWindow.ScrollColumn = 1
ActiveWindow.ScrollColumn = 20
Range("Z2").Select
Range("D2").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-2],'коды ТНВЭД'!R2C1:R3911C2,2,0)"
Selection.AutoFill Destination:=Range("D2:D10806")
Range("D2:D10806").Select
Range("P2").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-1],страны!R2C1:R256C2,2,0)"
Selection.AutoFill Destination:=Range("P2:P10806")
Range("P2:P10806").Select
ActiveWindow.ScrollColumn = 12
ActiveWindow.ScrollColumn = 29
Range("AL2").Select
ActiveCell.FormulaR1C1 = "=IF(RC[-1]=0,""С"")"
Range("AL2").Select
Selection.ClearContents
Range("AL2").Select
ActiveCell.FormulaR1C1 = "=IF(RC[-1]=0,""С"",0)"
Columns("AK:AK").Select
Range("AL2").Select
Range("AL2").Select
ActiveCell.FormulaR1C1 = "=IF(RC[-1]>0,0,""С"")"
Range("AK2").Select
ActiveCell.FormulaR1C1 = "1/0/1900"
Range("AK2").Select
Selection.Copy
Range("AL2").Select
Range("AK2").Select
Range("AL2").Select
Range("AL2").Select
ActiveCell.FormulaR1C1 = "=IF(RC[-3]=0,""С"")"
Selection.AutoFill Destination:=Range("AL2:AL10806")
Range("AL2:AL10806").Select
ActiveCell.FormulaR1C1 = "=IF(RC[-3]=0,""С"",""0"")"
Range("AL2").Select
Range("AL15").Select
Range("A2").Select
ActiveCell.FormulaR1C1 = "=1"
Range("V2").Select
Range("A3").Select
ActiveCell.FormulaR1C1 = "=IF(RC[17]=0,R[-1]C,R[-1]C+1)"
Selection.AutoFill Destination:=Range("A3:A10806")
Range("A3:A10806").Select
Range("V3").Select
ActiveCell.FormulaR1C1 = "=IF(RC[-4]=0,R[-1]C+1,1)"
Selection.AutoFill Destination:=Range("V3:V10806")
Range("V3:V10806").Select
Range("Z2:AA2").Select
Selection.AutoFill Destination:=Range("Z2:AA10806")
Range("Z2:AA703").Select
Range("AF2").Select
Selection.AutoFill Destination:=Range("AF2:AF10806")
Range("AF2:AF703").Select
ActiveWindow.SmallScroll Down:=276
ActiveWindow.ScrollRow = 647
ActiveWindow.SmallScroll Down:=45
ActiveWindow.ScrollRow = 7717
ActiveWindow.SmallScroll ToRight:=11
Range("AM2").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-14],ТРОИС!R1C1:R2138C5,2,0)"
Range("AN2").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-15],ТРОИС!R1C1:R2126C5,3,0)"
Range("AO2").Select
ActiveCell.FormulaR1C1 = "=VLOOKUP(RC[-16],ТРОИС!R2C1:R2412C4,4,0)"
Range("AM2:AO2").Select
Selection.AutoFill Destination:=Range("AM2:AO10806")
Range("AM2:AO703").Select
ActiveWindow.ScrollRow = 2190
ActiveWindow.SmallScroll Down:=-60
ActiveWindow.SmallScroll Down:=-114
Range("AI2").Select
Columns("AM:AO").Select
ActiveWorkbook.Save
Selection.Copy
Selection.PasteSpecial Paste:=xlPasteValuesAndNumberFormats, Operation:= _
xlNone, SkipBlanks:=False, Transpose:=False
Selection.Replace What:="#?/?", Replacement:="", LookAt:=xlWhole, _
SearchOrder:=xlByColumns, MatchCase:=False, SearchFormat:=False, _
Range("AN10").Select
Range("G3").Select
ActiveCell.FormulaR1C1 = "=IF(RC[-6]=R[-1]C[-6],,1)"
Selection.AutoFill Destination:=Range("G3:G10806")
Range("G3:G10806").Select
Range("H3").Select
ActiveCell.FormulaR1C1 = "=IF(RC[-7]=R[-1]C[-7],,""PK"")"
Selection.AutoFill Destination:=Range("H3:H10806")
Range("H3:H10806").Select
Columns("G:H").Select
Selection.Copy
Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
Range("AH2").Select
ActiveCell.FormulaR1C1 = "=IF(RC[1]=0,,""'01401"")"
ActiveCell.FormulaR1C1 = "=IF(RC[1]=0,,""01401"")"
Range("AH2").Select
Selection.AutoFill Destination:=Range("AH2:AH10806")
Range("AH2:AH10806").Select
Columns("AH:AH").Select
Selection.Copy
Columns("AL:AL").Select
Selection.Copy
Selection.Find(What:="0", After:=ActiveCell, LookIn:=xlFormulas, LookAt _
:=xlWhole, SearchOrder:=xlByColumns, SearchDirection:=xlNext, MatchCase _
:=False, SearchFormat:=False).Activate
Range("AI11").Select
ActiveWindow.SmallScroll Down:=147
ActiveWindow.ScrollRow = 7950
ActiveWindow.SmallScroll Down:=-18
Range("AK6").Select
ActiveCell.FormulaR1C1 = "=IF(RC[-8]=R[-1]C[-8],"""",RC[-4])"
Selection.AutoFill Destination:=Range("I2:I10806")
Range("I2:I10806").Select
При чем, если вот эту часть вынести в отдельный макрос, то ошибка не выскакивает
Сообщение отредактировал GalinaS - Вторник, 28.02.2023, 15:23
СообщениеПомогите, пожалуйста. Записывала макрос именно с помощью записи макроса. При выполнении макрос выдает ошибку Run-time error '1004': Метод Autofill из класса Range завершен неверно. Ругается на строчку Selection.AutoFill Destination:=Range("I2:I9806")
Cells.Select
Range("AJ7").Select
Range("Z2").Select
Range("D2").Select
Range("P2").Select
Range("AL2").Select
Range("AL2").Select
Range("AL2").Select
Range("AL2").Select
Range("AL2").Select
Range("AK2").Select
Range("AK2").Select
Selection.Copy
Range("AL2").Select
Range("AK2").Select
Range("AL2").Select
Range("AL2").Select
Range("AL2").Select
Range("A2").Select
Range("V2").Select
Range("A3").Select
Range("V3").Select
Range("AF2").Select
Range("AM2").Select
Range("AN2").Select
Range("AO2").Select
Range("AI2").Select
ActiveWorkbook.Save
Selection.Copy
Range("G3").Select
Range("H3").Select
Selection.Copy
Range("AH2").Select
Range("AH2").Select
Selection.Copy
Selection.Copy
Range("AK6").Select
Автор - GalinaS
Дата добавления - 28.02.2023 в 11:31
Pelena Дата: Вторник, 28.02.2023, 14:07 | Сообщение № 2
Репутация: 4672 ±
Можно попробовать обойтись без AutoFill
Например строки
Range("D2").Select
[/vba]можно заменить одной
Range("D2:D10806").FormulaR1C1 = "=VLOOKUP(RC[-2],'коды ТНВЭД'!R2C1:R3911C2,2,0)"
если по теме, то в конце вы делаете активной ячейку AK6, а автозаполнение пытаетесь сделать от этой ячейки по диапазону I2:I9806
СообщениеМожно попробовать обойтись без AutoFill
Например строки
Range("D2").Select
Дата добавления - 28.02.2023 в 14:07
GalinaS Дата: Вторник, 28.02.2023, 15:29 | Сообщение № 3
Pelena, спасибо Вам огромное, все заработало
Сообщение отредактировал GalinaS - Вторник, 28.02.2023, 15:29
СообщениеPelena, спасибо Вам огромное, все заработало
Автор - GalinaS
Дата добавления - 28.02.2023 в 15:29
