= Мир MS Excel/Доработка кода - Мир MS Excel
Доработка кода
swi040779 Дата: Вторник, 22.02.2022, 16:10 | Сообщение № 1
Замечаний: 80% ±
Ребята, подскажите где и что в коде поменять (добавить) чтобы суббота и воскресенье отображались красным?
Option Explicit
Dim StartDayWeek As Integer, CountFebrary As Integer
Dim Silence As Boolean
Dim CountDays As Integer
Dim ctl As Control
Dim Labels(0 To 41) As New DateClass
Dim lblYears(0 To 3) As New DateYearClass
Private Sub cmbMonth_Change()
If Silence Then Exit Sub
Silence = True
Mon = cmbMonth.ListIndex + 1
scbMonth.Value = Mon
Call Refresh(CurrentDay, Mon, CLng(CurrentYear))
Silence = False
Me.Caption = NameDayOfWeek(DayOfWeek(CurrentDay, Mon, CLng(CurrentYear))) & " " & CurrentDay & " " & MonthForDay(Mon) & " " & CurrentYear
Private Sub cmbMonth_KeyDown(ByVal KeyCode As MSForms.ReturnInteger, ByVal Shift As Integer)
If KeyCode = vbKeyV And Shift = 2 Then KeyCode = 0
If KeyCode = vbKeyDelete Then KeyCode = 0
If KeyCode = vbKeyBack Then KeyCode = 0
Private Sub cmbMonth_KeyPress(ByVal KeyAscii As MSForms.ReturnInteger)
KeyAscii = 0
Private Sub sbtSelectYear_Change()
Silence = True
On Error Resume Next
CurrentYear = Str(sbtSelectYear.Value)
tbxYear.Text = CurrentYear
lblYear1.Caption = Mid(CurrentYear, Len(CurrentYear), 1)
lblYear2.Caption = Mid(CurrentYear, Len(CurrentYear) - 1, 1)
lblYear3.Caption = Mid(CurrentYear, Len(CurrentYear) - 2, 1)
lblYear4.Caption = Mid(CurrentYear, Len(CurrentYear) - 3, 1)
Silence = False
Private Sub sbtSelectYear_Exit(ByVal Cancel As MSForms.ReturnBoolean)
Silence = True
Silence = False
Private Sub scbMonth_Change()
Silence = True
Mon = scbMonth.Value
cmbMonth.ListIndex = scbMonth.Value - 1
Silence = False
Private Sub tbxYear_Exit(ByVal Cancel As MSForms.ReturnBoolean)
Call ChangeYear
Private Sub tbxYear_KeyPress(ByVal KeyAscii As MSForms.ReturnInteger)
If KeyAscii < 48 Or KeyAscii > 57 Then KeyAscii = 0
Private Sub tbxYear_KeyDown(ByVal KeyCode As MSForms.ReturnInteger, ByVal Shift As Integer)
If KeyCode = vbKeyReturn Then
Call ChangeYear
cmbMonth.List = Split("Январь Февраль Март Апрель Май Июнь Июль Август Сентябрь Октябрь Ноябрь Декабрь")
Dim initDate As Date
initDate = IIf(IsDate(ActiveCell.Value), ActiveCell.Value, Date)
Silence = True
CurrentDay = Day(initDate)
CurrentYear = Trim(Str(Year(initDate)))
Mon = Month(initDate)
cmbMonth.Value = cmbMonth.List(Month(initDate) - 1)
StartDay = CurrentDay
StartMonth = Mon
StartYear = CurrentYear
sbtSelectYear.Value = CLng(CurrentYear)
Silence = False
Me.Left = 350
Me.Top = 250
Sub Refresh(Day As Integer, Month As Integer, Year As Long)
Dim CountDaysOfLastMonth As Integer
CurrentDay = Day
CountFebrary = IIf(Visok(Year), 29, 28)
CountDays = Choose(Month, 31, CountFebrary, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31)
StartDayWeek = DayOfWeek(1, Month, Year)
If Month = 1 Then
CountDaysOfLastMonth = 31
Else
CountDaysOfLastMonth = Choose(Month - 1, 31, CountFebrary, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31)
For Each ctl In DateForm.Controls
With ctl
If .Tag = "DateButton" Then
If .TabIndex < (StartDayWeek) Then
.Caption = CountDaysOfLastMonth - (StartDayWeek - ctl.TabIndex - 1)
.ForeColor = RGB(175, 175, 175)
.BackColor = Me.BackColor
'.SpecialEffect = fmSpecialEffectRaised
.SpecialEffect = fmSpecialEffectFlat
ElseIf .TabIndex > (StartDayWeek + CountDays - 1) Then
.Caption = .TabIndex - (StartDayWeek + CountDays) + 1
Else
.Caption = .TabIndex - StartDayWeek + 1
If (.TabIndex + 1) Mod 7 = 0 Then
.ForeColor = RGB(255, 0, 0)
Else
.ForeColor = RGB(0, 0, 0)
If .Caption = StartDay And Mon = StartMonth And CurrentYear = StartYear Then
.BackColor = RGB(255, 255, 255)
.SpecialEffect = fmSpecialEffectSunken
Else
Set Labels(.TabIndex).DateButton = ctl
If ctl.Tag = "YearButton" Then
Set lblYears(.TabIndex - 51).YearButton = ctl
Sub SelectTextBox()
ctl.Visible = False
Set lblYears(ctl.TabIndex - 51).YearButton = ctl
With tbxYear
.Visible = True
.SetFocus
Sub MoveCursor()
Dim MoveDay As Integer
With ctl
If .ForeColor <> RGB(175, 175, 175) Then
If .Caption = ActiveButton Then
.ForeColor = RGB(0, 0, 255)
MoveDay = .Caption
Else
Else
If Not (.Caption = StartDay And Mon = StartMonth And CurrentYear = StartYear) Then
Me.Caption = NameDayOfWeek(DayOfWeek(MoveDay, Mon, CLng(CurrentYear))) & " " & MoveDay & " " & MonthForDay(Mon) & " " & CurrentYear
Sub ChangeYear()
If Silence = True Then Exit Sub
Silence = True
lblYear1.Caption = Mid(tbxYear.Text, Len(tbxYear.Text), 1): If Not Err = 0 Then GoTo PASS
lblYear2.Caption = Mid(tbxYear.Text, Len(tbxYear.Text) - 1, 1): If Not Err = 0 Then lblYear2.Caption = ""
lblYear3.Caption = Mid(tbxYear.Text, Len(tbxYear.Text) - 2, 1): If Not Err = 0 Then lblYear3.Caption = ""
lblYear4.Caption = Mid(tbxYear.Text, Len(tbxYear.Text) - 3, 1): If Not Err = 0 Then lblYear4.Caption = ""
CurrentYear = tbxYear.Text
PASS:
lblYear1.Visible = True
lblYear2.Visible = True
lblYear3.Visible = True
lblYear4.Visible = True
tbxYear.Visible = False
Silence = False
[admin]Тема закрыта. Причина:Нарушения правил форума пп. 2, 3, 5f и 5r
Многократные повторные нарушения правил, игнорирование замечаний администрации
[/admin]
СообщениеРебята, подскажите где и что в коде поменять (добавить) чтобы суббота и воскресенье отображались красным?
Option Explicit
Dim ctl As Control
Silence = True
Silence = False
KeyAscii = 0
Silence = True
Silence = False
Silence = True
Silence = False
Silence = True
Silence = False
Call ChangeYear
Call ChangeYear
Silence = True
StartMonth = Mon
Silence = False
Me.Left = 350
Me.Top = 250
CurrentDay = Day
If Month = 1 Then
Else
With ctl
Else
Else
Else
Sub SelectTextBox()
ctl.Visible = False
With tbxYear
.Visible = True
.SetFocus
Sub MoveCursor()
With ctl
MoveDay = .Caption
Else
Else
Sub ChangeYear()
Silence = True
PASS:
Silence = False
[/admin]
Автор - swi040779
Дата добавления - 22.02.2022 в 16:10
