= Мир MS Excel/type mismatch error 13 в макросе - Мир MS Excel
Мир MS Excel » Вопросы и решения » Вопросы по VBA » type mismatch error 13 в макросе (Макросы/Sub)
prmdrk Дата: Четверг, 24.04.2014, 10:29 | Сообщение № 1
Никак не могу понять почему вылазит ошибка error 13 type mismatch в макросе
ошибку выдает на строку с
For Ii# = 3 To TransWbMaxRow
Public Mwb As Workbook
Public Mwb1 As Workbook
Public Asheet As Worksheet
Public Bsheet As Worksheet
Public TransWbMaxRow As Variant
Public TransWbMaxCol As Variant
Public GetMaxRow() As Variant
Public Arr_Art_Main(500000) As Variant
Public Arr_Art_Sub(500000) As Variant
Public Arr_Stock_Main(500000) As Variant
Public Arr_Art1(500000) As Variant
Public Arr_Art2(500000) As Variant
Public Arr_Art3(500000) As Variant
Public Arr_Art4(500000) As Variant
Public Arr_Art5(500000) As Variant
Public Arr_Art6(500000) As Variant
Public Arr_Art7(500000) As Variant
Public Arr_Art8(500000) As Variant
Public Arr_Art9(500000) As Variant
Public Arr_Art10(500000) As Variant
Public Arr_Art11(500000) As Variant
Public Arr_Art12(500000) As Variant
Public Arr_Priznak(500000) As Variant
Public Arr_Prod_name(500000) As Variant
Public Arr_Client_name_plan(500000) As Variant
Public Arr_Client_Prod_code_plan(500000) As Variant
Public Arr_Client_Prod_group_plan(500000) As Variant
Public Arr_Client_Prod_Qnt_plan(500000) As Variant
Public Arr_Client_Prod_Rub_plan(500000) As Variant
Public Arr_Client_Prod_Kg_plan(500000) As Variant
Public Arr_Client_Prod_Name_plan(500000) As Variant
Public Arr_Client_Prod_Weight(500000) As Variant
Public Arr_Client_Prod_Price(500000) As Variant
Public Arr_Client_Prod_OOS(500000) As Variant
Public Arr_Client_Prod_Group(500000) As Variant
Public Arr_Client_Prod_code_actual(500000) As Variant
Public Arr_Client_Name_actual(500000) As Variant
Public Arr_Client_Prod_Qnt_Sales(500000) As Variant
Public Arr_Client_Prod_Qnt_Transit(500000) As Variant
Public Arr_Client_Prod_Qnt_Order(500000) As Variant
Public Arr_Client_Region(500000) As Variant
Public Client_Cognos(500000) As Variant
Public Client_Cognos_Addr(500000) As Variant
Public Client_CisLink(500000) As Variant
Sub Download_plan_fact_client()
Set Mwb = ActiveWorkbook
Client$ = Range("A1").Value
If Len(Client$) = 0 Then
MsgBox "Íå âûáðàí êëèåíò!"
Range("A1").Activate
End
aaa% = MsgBox("Äîáàâèòü äàííûå ïî ïëàíó è ôàêòó äëÿ " & Client$ & "?", vbYesNo + vbInformation, "Âíèìàíèå.")
If aaa% <> vbYes Then
End
'''Âûãðóçèì òåêóùèå ïðîäàæè'''
Mwb.Sheets("Details").Activate
TransWbMaxRow = GetMaxRow()
cnt1# = 0
If Len(Trim(Cells(Ii#, 1).Value)) = 0 Then Exit For
If Trim(Cells(Ii#, 1).Value) = Client$ Then
cnt1# = cnt1# + 1
Arr_Client_Prod_code_actual(cnt1#) = Trim(Cells(Ii#, 3).Value)
Arr_Client_Prod_Qnt_Sales(cnt1#) = Val(Cells(Ii#, 12).Value) ' ïðîäàæè, çàêàçû, òðàíçèòû â øò
Arr_Client_Prod_Qnt_plan(cnt1#) = Val(Cells(Ii#, 6).Value) ' ïëàí, øò
Arr_Client_Prod_OOS(cnt1#) = Trim(Cells(Ii#, 26).Value)
Arr_Client_Prod_Group(cnt1#) = Trim(Cells(Ii#, 27).Value)
Next Ii#
Mwb.Sheets("Checking").Activate
''''' Óäàëåíèå ñòàðûõ äàííûõ
For Ii# = 4 To TransWbMaxRow
Cells(Ii#, 4).Value = ""
Cells(Ii#, 5).Value = 0
Cells(Ii#, 6).Value = 0
Cells(Ii#, 8).Value = 0
Next Ii#
For j# = 1 To cnt1#
If Trim(Cells(Ii#, 2).Value) = Arr_Client_Prod_code_actual(j#) Then
Cells(Ii#, 4).Value = Arr_Client_Prod_Group(j#)
Cells(Ii#, 5).Value = Arr_Client_Prod_Qnt_plan(j#)
Cells(Ii#, 6).Value = Arr_Client_Prod_Qnt_Sales(j#)
If Arr_Client_Prod_OOS(j#) = "-" Then
Cells(Ii#, 3).Value = "Äà"
Exit For
Next j#
Next Ii#
Сообщение отредактировал Serge_007 - Четверг, 09.07.2015, 10:13
СообщениеНикак не могу понять почему вылазит ошибка error 13 type mismatch в макросе
End
End
cnt1# = 0
cnt1# = cnt1# + 1
Next Ii#
Next Ii#
For j# = 1 To cnt1#
Exit For
Next j#
Next Ii#
Автор - prmdrk
Дата добавления - 24.04.2014 в 10:29
Gustav Дата: Четверг, 24.04.2014, 10:55 | Сообщение № 2
Репутация: 1137 ±
Вставьте перед этой строкой оператор Debug.Print VarType(TransWbMaxRow), посмотрите что приходит в этой переменной к началу цикла. Расшифровка возвращаемых кодов - по F1 на VarType.
СообщениеВставьте перед этой строкой оператор Debug.Print VarType(TransWbMaxRow), посмотрите что приходит в этой переменной к началу цикла. Расшифровка возвращаемых кодов - по F1 на VarType.
Автор - Gustav
Дата добавления - 24.04.2014 в 10:55
prmdrk Дата: Четверг, 24.04.2014, 11:04 | Сообщение № 3
вставил данную строку. Ничего не появилось, ругается на ту же строку.
Сообщениевставил данную строку. Ничего не появилось, ругается на ту же строку.
Автор - prmdrk
Дата добавления - 24.04.2014 в 11:04
Gustav Дата: Четверг, 24.04.2014, 11:09 | Сообщение № 4
Репутация: 1137 ±
Окно отладки (Immediate window) откройте (по Ctrl+G, например). Раньше совсем не приходилось отладкой кода на VBA заниматься?
СообщениеОкно отладки (Immediate window) откройте (по Ctrl+G, например). Раньше совсем не приходилось отладкой кода на VBA заниматься?
Автор - Gustav
Дата добавления - 24.04.2014 в 11:09
prmdrk Дата: Четверг, 24.04.2014, 11:14 | Сообщение № 5
совсем, пытаюсь разобраться постольку поскольку, чтобы автоматизировать некоторые рабочие свои моменты.
В отладку пришло 8204.
Сообщениесовсем, пытаюсь разобраться постольку поскольку, чтобы автоматизировать некоторые рабочие свои моменты.
Автор - prmdrk
Дата добавления - 24.04.2014 в 11:14
Gustav Дата: Четверг, 24.04.2014, 11:28 | Сообщение № 6
Репутация: 1137 ±
Всё, что больше, чем 8192 - это массив (array) того типа, который получается при вычитании 8192. Т.е. у вас это массив 8204-8192 = 12, т.е. vbVariant. Таким образом, верхняя граница цикла задана массивом, а не простым значением. Собственно у вас всё так и обявлено: Public GetMaxRow() As Variant. Две скобки в данном случае - это динамический массив. А в программе дальше вы почему-то используете его как функцию - не обижайтесь, но бред какой-то, если честно...
P.S. По сути функция в местах присваивания напрашивается больше, но тогда где ее код? И надо строку Public GetMaxRow() As Variant убрать из объявлений. Т.е. у вас должна появиться Function GetMaxRow(), которая каким-то образом должна вычислять максимальную строку, судя по смыслу названия.
Сообщение отредактировал Gustav - Четверг, 24.04.2014, 11:34
Автор - Gustav
Дата добавления - 24.04.2014 в 11:28
prmdrk Дата: Четверг, 24.04.2014, 11:35 | Сообщение № 7
ни в коем разе не обижаюсь=) есть ли возможность поправить то что есть, или надо переписывать все?
Сообщениени в коем разе не обижаюсь=) есть ли возможность поправить то что есть, или надо переписывать все?
Автор - prmdrk
Дата добавления - 24.04.2014 в 11:35
Gustav Дата: Четверг, 24.04.2014, 11:40 | Сообщение № 8
Репутация: 1137 ±
Малой кровью это примерно так:
1. Убираем строку Public GetMaxRow() As Variant.
2. В самом низу пишем функцию:
Public Function GetMaxRow() As Long
     бла-бла-бла
     GetMaxRow = ...
End Function
Сообщение отредактировал Gustav - Четверг, 24.04.2014, 11:40
     бла-бла-бла
     GetMaxRow = ...
End Function
Автор - Gustav
Дата добавления - 24.04.2014 в 11:40
prmdrk Дата: Четверг, 24.04.2014, 11:46 | Сообщение № 9
Спасибо!
Сработало после вставки.
Function GetMaxRow() As Variant
      On Error GoTo met2
      GetMaxRow = ActiveCell.SpecialCells(xlLastCell).Row
      Exit Function
met2:
      Resume Next
End Function
СообщениеСпасибо!
      On Error GoTo met2
      Exit Function
met2:
      Resume Next
End Function
Автор - prmdrk
Дата добавления - 24.04.2014 в 11:46
Zaga83 Дата: Вторник, 25.07.2017, 16:08 | Сообщение № 10
Всем привет!!!
Помогите разобраться
Пытаюсь проверить через клавишу F8
этот код.
Выходит сообщение, ошибка 13.
как исправить не могу понять, так как не могу понять как мне объявить переменную MyShortDate?
[color=blue]Public Sub Пример_функции_Датат()
Dim MyDate As String, MyTime, MyShortTime
Dim MyShortDate
MyDate = "February 12, 1969" ' Define date.
MyShortDate = CDate(MyDate)' Convert to Date data type.
MyTime = "4:35:47 PM" ' Define time.
MyShortTime = CDate(MyTime) ' Convert to Date data type.
End Sub[/color]
К сообщению приложен файл: __.xls (31.5 Kb)
Сообщение отредактировал Zaga83 - Вторник, 25.07.2017, 16:13
СообщениеВсем привет!!!
этот код.
Dim MyShortDate
End Sub[/color]
Автор - Zaga83
Дата добавления - 25.07.2017 в 16:08
_Boroda_ Дата: Вторник, 25.07.2017, 16:14 | Сообщение № 11
Репутация: 6481 ±
Zaga83, Последнее китайское предупреждение - прочитайте полностью Правила форума
http://www.excelworld.ru/forum/2-20-1
и как пользоваться тегами
http://www.excelworld.ru/forum/13-2708-1
СообщениеZaga83, Последнее китайское предупреждение - прочитайте полностью Правила форума
Дата добавления - 25.07.2017 в 16:14
