= Мир MS Excel/Извлечение части данных из ячейки и сортировка в таблице - Мир MS Excel
Frodoobek Дата: Суббота, 29.04.2017, 13:03 | Сообщение № 1
Из Access экспортировали таблицу в Excel. В каждой ячейке одного из столбцов находится большой объем данных, например:
OBJECT PUMP
IDENT NKM-GE 50-125/141 M MCE
NEWID {CHARSFDPN[Kl];;;0}/{Matcd[Ws];;;0}/BAQE/{POWER[M];;kW;0;;;;;;,}/{POLES[M];;;0} {CHARSFDPN[M];;;0} MCE11/C
SHORTNAME DAB
DATA NKM-GE NKP-GE MCE completo NKM-GE NKP-GE MCE breve
LIMITIND 0 0
LIMIT Tminfluido 1 [P] 6 32 0 -10 -10
LIMIT Tmaxfluido 1 [P] 6 32 0 140 140
LIMIT Tmaxambiente 1 [P] 6 32 0 40 40
PAGENO 5
SERIES NKM-GE NKP-GE MCE-C my11
DATASHEET DAB - scheda tecnica pompe centrifughe MCE MEI DAB - hydraulic DAB - dimension -
PERFORMANCECHART NKM-GE 50-125/141 MCE MY11 NKM-GE 50-125/141 MCE MY11
TYPE 3 All
SAFETYMARGIN 5 1 0 1
RESISTANCE 0
MATERIALKEY NKM-GE NKP-GE MCE Ghisa 0
GRIDCOLUMNS ARTNR[P]
GRIDCOLUMNS NAME[DNs]
GRIDCOLUMNS NAME[DNd]
GRIDCOLUMNS POLES[M]
GRIDCOLUMNS POWER[M]
GRIDCOLUMNS SPEED[M]
MEASUREMENT A 100
MEASUREMENT B 50
MEASUREMENT DNA 65
MEASUREMENT DNM 50
MEASUREMENT G 250
MEASUREMENT H1 132
MEASUREMENT H2 160
MEASUREMENT L 680
MEASUREMENT M1 100
MEASUREMENT M2 70
MEASUREMENT N1 240
MEASUREMENT N2 190
MEASUREMENT S1 M10
MEASUREMENT Y 262
OPTION 1
ORIFICELIMIT 0,1 0,9 0
OBJECT INSTALLATION
IDENT Monoblocco elettroniche
SHORTNAME DAB
FILENAME NKM-GE MCE dimensioni
WEIGHT 55
LIMITIND 0 0
LIMIT MEDT 1 [AW] 6 11 1 -10 140
WEIGHTFORMULA $Wg :=$Wg[AV]
ACCSALLOC NKM-GE NKP-GE NKM NKP
FIELDS 0 0
HIDECOMP [AV]
HIDECOMP [DN]
HIDECOMP [DNd]
HIDECOMP [DNs]
HIDECOMP [M]
HIDECOMP [Ws]
FORMULA A := A[P]
FORMULA B := B[P]
FORMULA DNA := DNA[P]
FORMULA DNM := DNM[P]
FORMULA G := G[P]
FORMULA H1 := H1[P]
FORMULA H2 := H2[P]
FORMULA L := L[P]
FORMULA M1 := M1[P]
FORMULA M2 := M2[P]
FORMULA N1 := N1[P]
FORMULA N2 := N2[P]
FORMULA S1 := S1[P]
FORMULA Y := Y[P]
PRICEALLOC P 0 {RESULTID[P];;;0}
ZUSEIAVTOGUI 1
OBJECT FLANGES
IDENT DN 65 / DN 50
SHORTNAME DAB
SUCTIONSIDE DN 65
DISCHARGESIDE DN 50
VALUES DIN 2533 PN 16
VALUESSUCT DIN 2533 PN 16
OBJECT CHECK
OBJECT USERINFO
IDENT Foto
SHORTNAME DAB
FILENAME NKM-GE_NKP-GE MCE Foto
OBJECT USERINFO
IDENT Libretto
SHORTNAME DAB
FILENAME Cod_001354001.pdf
OBJECT USERINFO
IDENT Catalogo tecnico
SHORTNAME DAB
FILENAME CAT14_NKM-GE_NKP-GE.pdf
OBJECT USERINFO
IDENT Libretto inverter
SHORTNAME DAB
FILENAME Cod_60140130.pdf
OBJECT USERINFO
IDENT Dichiarazione di conformita
SHORTNAME DAB
FILENAME Cod_60164947.pdf
OBJECT USERINFO
IDENT CAD
SHORTNAME DAB
FILENAME NKM-GE_50.rar
LIMITIND 0 0
LIMIT FREQ 0 [M] 0 11 0 50
Требуется каким-то образом выудить из этой мешанины необходимые данные и разместить в соответствующие ячейки в другой таблице.
Например MEASUREMENT - параметр габаритов:
MEASUREMENT A 100
MEASUREMENT B 50
MEASUREMENT DNA 65
MEASUREMENT DNM 50
Значит габарит A = 100
Габарит B = 50
Габарит DNA = 65
Габарит DNM = 50
и т.д.
В конечном итоге, хотелось бы получить один столбец с наименованием габарита (A, B, DNA, DNM и т.д.), и в соседних ячейках - значения соответствующие этим габаритам.
Во вложении сам файл, но в обрезанном виде, т.к. оригинал весит порядка 12Мб.. Интересующий столбец - H.
Это самое главное, что хотелось бы выудить из этого объема данных, но если получится, посмотрим, что можно еще выудить.
Заранее спасибо. Прошу сильно не пинать, если написал непонятно, задавайте вопросы - буду отвечать на них. На форуме находил похожие темы, но не смог применить для своих целей, поэтому прошу помощи конкретно в моем случае.
К сообщению приложен файл: Data_.xlsx (28.8 Kb)
Сообщение отредактировал Frodoobek - Суббота, 29.04.2017, 20:00
СообщениеИз Access экспортировали таблицу в Excel. В каждой ячейке одного из столбцов находится большой объем данных, например:
OBJECT PUMP
SHORTNAME DAB
LIMITIND 0 0
PAGENO 5
TYPE 3 All
RESISTANCE 0
MEASUREMENT A 100
MEASUREMENT B 50
MEASUREMENT DNA 65
MEASUREMENT DNM 50
MEASUREMENT G 250
MEASUREMENT H1 132
MEASUREMENT H2 160
MEASUREMENT L 680
MEASUREMENT M1 100
MEASUREMENT M2 70
MEASUREMENT N1 240
MEASUREMENT N2 190
MEASUREMENT S1 M10
MEASUREMENT Y 262
OPTION 1
OBJECT INSTALLATION
SHORTNAME DAB
WEIGHT 55
LIMITIND 0 0
FIELDS 0 0
HIDECOMP [AV]
HIDECOMP [DN]
HIDECOMP [DNd]
HIDECOMP [DNs]
HIDECOMP [M]
HIDECOMP [Ws]
FORMULA A := A[P]
FORMULA B := B[P]
FORMULA G := G[P]
FORMULA H1 := H1[P]
FORMULA H2 := H2[P]
FORMULA L := L[P]
FORMULA M1 := M1[P]
FORMULA M2 := M2[P]
FORMULA N1 := N1[P]
FORMULA N2 := N2[P]
FORMULA S1 := S1[P]
FORMULA Y := Y[P]
ZUSEIAVTOGUI 1
OBJECT FLANGES
IDENT DN 65 / DN 50
SHORTNAME DAB
SUCTIONSIDE DN 65
DISCHARGESIDE DN 50
OBJECT CHECK
OBJECT USERINFO
IDENT Foto
SHORTNAME DAB
OBJECT USERINFO
IDENT Libretto
SHORTNAME DAB
OBJECT USERINFO
SHORTNAME DAB
OBJECT USERINFO
SHORTNAME DAB
OBJECT USERINFO
SHORTNAME DAB
OBJECT USERINFO
IDENT CAD
SHORTNAME DAB
LIMITIND 0 0
MEASUREMENT A 100
MEASUREMENT B 50
MEASUREMENT DNA 65
MEASUREMENT DNM 50
Габарит B = 50
Габарит DNA = 65
Габарит DNM = 50
и т.д.
Автор - Frodoobek
Дата добавления - 29.04.2017 в 13:03
skais675 Дата: Суббота, 29.04.2017, 14:37 | Сообщение № 2
Репутация: 3 ±
Замечаний: 100% ±
Вложения нет! Это больше ТЗ чем просто вопросы. Обратитесь в платный раздел и Вам сразу помогут.
Vlad
skype: skais675
email: skais675@mail.ru
СообщениеВложения нет! Это больше ТЗ чем просто вопросы. Обратитесь в платный раздел и Вам сразу помогут.
Автор - skais675
Дата добавления - 29.04.2017 в 14:37
Frodoobek Дата: Суббота, 29.04.2017, 20:02 | Сообщение № 3
Извините за отсутствие вложения. Моя ошибка, не увидел. Сейчас приложил.
Автор - Frodoobek
Дата добавления - 29.04.2017 в 20:02
Pelena Дата: Суббота, 29.04.2017, 21:04 | Сообщение № 4
Репутация: 4661 ±
Два варианта: формулой и пользовательской функцией
К сообщению приложен файл: Data_.xlsm (40.9 Kb)
СообщениеДва варианта: формулой и пользовательской функцией
Дата добавления - 29.04.2017 в 21:04
skais675 Дата: Суббота, 29.04.2017, 21:32 | Сообщение № 5
Репутация: 3 ±
Замечаний: 100% ±
Pelena - если строго для одного параметра то да, а если для кучи параметров, то без макроса никак, а это уже тз. (возможно я ошибаюсь)
Vlad
skype: skais675
СообщениеPelena - если строго для одного параметра то да, а если для кучи параметров, то без макроса никак, а это уже тз. (возможно я ошибаюсь)
Автор - skais675
Дата добавления - 29.04.2017 в 21:32
Pelena Дата: Суббота, 29.04.2017, 21:43 | Сообщение № 6
Репутация: 4661 ±
для кучи параметров
Для какой кучи?
Покажите своё решение, или Вы только критиковать умеете?
Вы ошибаетесь. Я ещё раз предупреждаю, не надо необоснованно посылать ТС в платный раздел
для кучи параметров
Для какой кучи?
Дата добавления - 29.04.2017 в 21:43
Frodoobek Дата: Суббота, 29.04.2017, 21:53 | Сообщение № 7
Pelena, спасибо за ответ. Пробую разобраться в вашем способе, чтобы попробовать его применить под другие параметры.
Но в любом случае огромное вам спасибо.
Сообщение отредактировал Frodoobek - Суббота, 29.04.2017, 21:53
СообщениеPelena, спасибо за ответ. Пробую разобраться в вашем способе, чтобы попробовать его применить под другие параметры.
Автор - Frodoobek
Дата добавления - 29.04.2017 в 21:53
skais675 Дата: Суббота, 29.04.2017, 21:59 | Сообщение № 8
Репутация: 3 ±
Замечаний: 100% ±
Pelena, Сорри, Вы правы несомненно, придержусь Вашего совета, не буду больше посылать ТС в платный раздел.
Vlad
skype: skais675
СообщениеPelena, Сорри, Вы правы несомненно, придержусь Вашего совета, не буду больше посылать ТС в платный раздел.
Автор - skais675
Дата добавления - 29.04.2017 в 21:59
Frodoobek Дата: Понедельник, 01.05.2017, 10:40 | Сообщение № 9
Начал применять к бОльшему количеству данных. И оказалось, что появляются дополнительные значения габаритов для других серий товаров. При использовании функции вроде бы считает правильно но не везде. Отметил желтым строки для примера, где не бьются значения. Как будто формула свои какие-то значения выдумывает.
Посмотрите, пожалуйста, что я упустил или понял не так в вашем решении.
К сообщению приложен файл: Data-.xlsm (89.2 Kb)
Сообщение отредактировал Frodoobek - Понедельник, 01.05.2017, 11:17
Автор - Frodoobek
Дата добавления - 01.05.2017 в 10:40
Pelena Дата: Понедельник, 01.05.2017, 11:10 | Сообщение № 10
Репутация: 4661 ±
Не нужны все данные. Оставьте десяток строк, в том числе с ошибкой, и прикладывайте сюда
СообщениеНе нужны все данные. Оставьте десяток строк, в том числе с ошибкой, и прикладывайте сюда
Дата добавления - 01.05.2017 в 11:10
Frodoobek Дата: Понедельник, 01.05.2017, 15:12 | Сообщение № 11
Изменил прошлое сообщение. Ваше не успел на тот момент прочитать.
Автор - Frodoobek
Дата добавления - 01.05.2017 в 15:12
Pelena Дата: Понедельник, 01.05.2017, 15:16 | Сообщение № 12
Репутация: 4661 ±
У Вас данные берутся из разных строк. Например, в ячейке А2 идёт ссылка на Data!F2, а в ячейке B2 почему-то на Data!$H4, хотя должно быть на Data!$H2
Отсюда и "чужие" значения
СообщениеУ Вас данные берутся из разных строк. Например, в ячейке А2 идёт ссылка на Data!F2, а в ячейке B2 почему-то на Data!$H4, хотя должно быть на Data!$H2
Дата добавления - 01.05.2017 в 15:16
Frodoobek Дата: Понедельник, 01.05.2017, 15:49 | Сообщение № 13
Посмотрел ваше замечание, но как раз в этом плане - все нормально. Ссылка на F2 шла для того, чтобы я понимал наименование товара. Эта строчка только для меня, не для формулы.
Но в процессе разбора увидел, что, действительно, часть ссылок была не верной и выдавались неправильные значения. В данной версии файла все исправил.
И появилась новая беда: я желтым в таблице отметил, что если требуемый параметр состоит из букв и цифр, например, B2, то в случае данных параметра B2=610, в таблице я получаю и данные B=2610. Это, кстати, относится ко всем параметрам, имеющим название не только буквенное, но и числовое.
Можно ли как-то уберечься от подобного явления?
Автор - Frodoobek
Дата добавления - 01.05.2017 в 15:49
Pelena Дата: Понедельник, 01.05.2017, 16:08 | Сообщение № 14
Репутация: 4661 ±
Файл не приложился, но попробуйте так, вдруг правильно)
К сообщению приложен файл: Data-1-.xlsm (26.6 Kb)
СообщениеФайл не приложился, но попробуйте так, вдруг правильно)
Дата добавления - 01.05.2017 в 16:08
Frodoobek Дата: Вторник, 02.05.2017, 06:02 | Сообщение № 15
вдруг правильно)
Правильно :)
К сожалению, вылезло еще кое-что. Оказывается ваша формула чувствительна к регистру. В большинстве своем значения параметров пишутся с заглавных букв, например "MEASUREMENT A", но есть небольшая (товаров 50), у которых прописано так: "MEASUREMENT a". Функция пропускает данные параметры.
Можно как-то убрать чувствительность к регистру значений?
____
Если это сложно и нет времени, то не отвечайте. Я немного по-своему решил используя функцию =ПРОПИСН для начальных данных. Теперь все отображается.
Сообщение отредактировал Frodoobek - Вторник, 02.05.2017, 06:09
вдруг правильно)
Правильно :)
____
Автор - Frodoobek
Дата добавления - 02.05.2017 в 06:02
Pelena Дата: Вторник, 02.05.2017, 08:46 | Сообщение № 16
Репутация: 4661 ±
Такую же функцию можно использовать в макросе.
После строки
For i = 0 To UBound(s)
добавьте строчку
s(i) = UCase(s(i))
СообщениеТакую же функцию можно использовать в макросе.
После строки
добавьте строчку
s(i) = UCase(s(i))
Дата добавления - 02.05.2017 в 08:46
