= Мир MS Excel/Записи участника (krosav4ig) - Мир MS Excel
Результаты поиска
krosav4ig Дата: Четверг, 01.02.2018, 00:33 | Сообщение № 1521 | Тема: Перемещение UserForm в любую область
Репутация: 997 ±
Excel 2007,2010,2013
Option Explicit
    'константы для функций API
    Private Const GWL_STYLE As Long = -16& 'для установки нового вида окна
    Private Const GWL_EXSTYLE = -20& 'для расширенного стиля окна
    Private Const WS_CAPTION As Long = &HC00000 'определяет заголовок
    Private Const WS_BORDER As Long = &H800000 'определяет рамку формы
    Private Const WM_NCLBUTTONDOWN = &HA1
    Private Const HTCAPTION = 2
    'Функции API, применяемые для поиска окна и изменения его стиля
#If VBA7 Then
    Private Declare PtrSafe Function SetWindowLong Lib "User32" Alias "SetWindowLongA" (ByVal hwnd As LongPtr, ByVal nIndex As Long, ByVal dwNewLong As LongPtr) As LongPtr
    Private Declare PtrSafe Function GetWindowLong Lib "User32" Alias "GetWindowLongA" (ByVal hwnd As LongPtr, ByVal nIndex As Long) As LongPtr
    Private Declare PtrSafe Function FindWindow Lib "User32" Alias "FindWindowA" (ByVal lpClassName As String, ByVal lpWindowName As String) As LongPtr
    Private Declare PtrSafe Function DrawMenuBar Lib "User32" (ByVal hwnd As LongPtr) As Long
    Private Declare PtrSafe Function SendMessage Lib "user32" Alias "SendMessageA"  (ByVal hwnd As LongPtr, ByVal wMsg As Long, ByVal wParam As LongPtr, lParam As Any) As LongPtr
    Private Declare PtrSafe Sub ReleaseCapture Lib "user32" ()
    Dim ihWnd As LongPtr
#Else
    Private Declare Function SetWindowLong Lib "user32" Alias "SetWindowLongA" (ByVal hwnd As Long, ByVal nIndex As Long, ByVal dwNewLong As Long) As Long
    Private Declare Function GetWindowLong Lib "user32" Alias "GetWindowLongA" (ByVal hwnd As Long, ByVal nIndex As Long) As Long
    Private Declare Function FindWindow Lib "user32.dll" Alias "FindWindowA" (ByVal lpClassName As String, ByVal lpWindowName As String) As Long
    Private Declare Function DrawMenuBar Lib "user32.dll" (ByVal hwnd As Long) As Long
    Private Declare Function SendMessage Lib "user32" Alias "SendMessageA" (ByVal hwnd As Long, ByVal wMsg As Long, ByVal wParam As Long, lParam As Any) As Long
    Private Declare Sub ReleaseCapture Lib "user32" ()
    Dim ihWnd As Long
#End If
    Dim hStyle
    'ищем окно формы среди всех открытых окон
    If VAL(Application.Version) < 9 Then
        ihWnd = FindWindow("ThunderXFrame", Me.Caption) 'для Excel 97
    Else
        ihWnd = FindWindow("ThunderDFrame", Me.Caption) 'для Excel 2000 и выше
    'получаем информацию о найденном окне(стили и т.д.)
    hStyle = GetWindowLong(ihWnd, GWL_STYLE)
    'назначаем переменной новый стиль для окна формы
    hStyle = hStyle And Not WS_CAPTION And Not WS_BORDER
    'изменяем вид окна: убираем меню(заголовок) и рамку
    SetWindowLong ihWnd, GWL_STYLE, hStyle
    SetWindowLong ihWnd, GWL_EXSTYLE, 0
    'перерисовываем форму, точнее строку меню(заголовка)
    DrawMenuBar ihWnd
    'меняем размер формы, т.к. сделали смещение элементов формы вверх на высоту заголовка
    Me.Height = Me.Height + GWL_EXSTYLE
Private Sub UserForm_MouseDown(ByVal Button As Integer, ByVal Shift As Integer, ByVal X As Single, ByVal Y As Single)
    If Button = 1 Then
        ReleaseCapture
        SendMessage ihWnd, WM_NCLBUTTONDOWN, HTCAPTION, 0&
Private Sub ЗАКРЫТЬ_Click()
    Unload Me
Сообщение отредактировал krosav4ig - Четверг, 01.02.2018, 00:33
Option Explicit
#If VBA7 Then
#Else
    Dim ihWnd As Long
#End If
    Dim hStyle
    Else
    DrawMenuBar ihWnd
    If Button = 1 Then
        ReleaseCapture
    Unload Me
Автор - krosav4ig
Дата добавления - 01.02.2018 в 00:33
krosav4ig Дата: Четверг, 01.02.2018, 03:35 | Сообщение № 1522 | Тема: Макрос: ввод чч:мм:сс без двоеточий.
Репутация: 997 ±
Здравствуйте
Можно как-то так
В модуль ЭтаКнига
Private Sub Workbook_SheetChange(ByVal Sh As Object, ByVal Target As Range)
    With Target
        If .NumberFormat = "[h]:mm:ss" And Int(.Value) = .Value Then
            .Formula = Format(.Formula, "00:00:00")
К сообщению приложен файл: 0579909.xlsm (34.4 Kb)
СообщениеЗдравствуйте
Можно как-то так
В модуль ЭтаКнига
    With Target
Автор - krosav4ig
Дата добавления - 01.02.2018 в 03:35
krosav4ig Дата: Четверг, 01.02.2018, 14:26 | Сообщение № 1523 | Тема: Перенос значения ячейки с изменением формата и коррект.
Репутация: 997 ±
=ЕСЛИОШИБКА(ОСТАТ(ПСТР(ПОДСТАВИТЬ(","&$A1;",";ПОВТОР(" ";99));99*СТОЛБЕЦ(A1);99);10^7);"")
К сообщению приложен файл: 2014932.xls (26.0 Kb)
Автор - krosav4ig
Дата добавления - 01.02.2018 в 14:26
krosav4ig Дата: Четверг, 01.02.2018, 14:46 | Сообщение № 1524 | Тема: Сравнение 2 столбцов с датами
Репутация: 997 ±
=C2=КОНМЕСЯЦА(B2;0)+1
К сообщению приложен файл: 3561139.xls (19.0 Kb)
Автор - krosav4ig
Дата добавления - 01.02.2018 в 14:46
krosav4ig Дата: Четверг, 01.02.2018, 15:43 | Сообщение № 1525 | Тема: Автопродление отдельных столбцов умной таблицы
Репутация: 997 ±
Добрый день
В Excel 2007 было как-то так
открыть Параметры автозамены, на вкладке "Автоформат при вводе" поставить галочку "Включать в таблицу новые строки"
СообщениеДобрый день
Автор - krosav4ig
Дата добавления - 01.02.2018 в 15:43
krosav4ig Дата: Четверг, 01.02.2018, 17:25 | Сообщение № 1526 | Тема: Автопродление отдельных столбцов умной таблицы
Репутация: 997 ±
можно еще реестр проверить
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Office\16.0\Word\Options]
"autoexpandlistrange"=dword:00000001
К сообщению приложен файл: key.reg (0.1 Kb)
Сообщениеможно еще реестр проверить
Автор - krosav4ig
Дата добавления - 01.02.2018 в 17:25
krosav4ig Дата: Четверг, 01.02.2018, 21:48 | Сообщение № 1527 | Тема: перенос текста по строкам вверх, при выборе приоритетности
Репутация: 997 ±
Сообщение отредактировал krosav4ig - Четверг, 01.02.2018, 22:37
СообщениеЗдрасте.
Сортировка данных в диапазоне или таблице
Автор - krosav4ig
Дата добавления - 01.02.2018 в 21:48
krosav4ig Дата: Четверг, 01.02.2018, 22:38 | Сообщение № 1528 | Тема: перенос текста по строкам вверх, при выборе приоритетности
Репутация: 997 ±
Исправил
СообщениеИсправил
Автор - krosav4ig
Дата добавления - 01.02.2018 в 22:38
krosav4ig Дата: Пятница, 02.02.2018, 05:58 | Сообщение № 1529 | Тема: заполнение полей формы значениями выделенной строки
Репутация: 997 ±
на всякий случай
Option Explicit
Private LO As ListObject
Private index%
Private Sub UserForm_QueryClose(Cancel As Integer, CloseMode As Integer)
    Set LO = Nothing
Private Sub ИмяПациента_Change()
Private Sub ИмяТовара_Change()
Private Sub КачествоТовара_Change()
Private Sub КоличествоТовара_Change()
    Set LO = [Таблица2].ListObject
    With LO
        If Intersect(.DataBodyRange, Selection) Is Nothing Then
            Set LO = Nothing
            Exit Sub
        index = Selection.Row - .HeaderRowRange.Row
        With .ListColumns
            Me.ИмяПациента = .Item("Имя").DataBodyRange(index)
            Me.ИмяТовара = .Item("Товар").DataBodyRange(index)
            Me.КоличествоТовара = .Item("Количество").DataBodyRange(index)
            Me.КачествоТовара = .Item("Качество").DataBodyRange(index)
Private Sub Редактура_Click()
    LO.ListRows(index).Range = Array(ИмяПациента, ИмяТовара, КоличествоТовара, КачествоТовара)
Private Sub ОчисткаФормы_Click()
    Me.ИмяПациента = Empty
    Me.ИмяТовара = Empty
    Me.КоличествоТовара = Empty
    Me.КачествоТовара = Empty
Private Sub СозданиеНового_Click()
    LO.ListRows.Add.Range = Array(ИмяПациента, ИмяТовара, КоличествоТовара, КачествоТовара)
Private Sub Выход_Click()
    Unload Me
Сообщениена всякий случай
Option Explicit
Private index%
    Set LO = Nothing
    With LO
            Set LO = Nothing
            Exit Sub
        With .ListColumns
    Unload Me
Автор - krosav4ig
Дата добавления - 02.02.2018 в 05:58
krosav4ig Дата: Пятница, 02.02.2018, 15:03 | Сообщение № 1530 | Тема: Перенос значения ячейки с изменением формата и коррект.
Репутация: 997 ±
Вариант с UDF
Function Перенос$(s$)
    With CreateObject("vbscript.regexp")
        .Pattern = "(\d{1,3}(?=\d{4}))|\d+"
        .Global = True
        s = .Replace(StrReverse(s), "$1 ")
    Перенос = StrReverse(Application.Trim(s))
End Function
К сообщению приложен файл: 7236614.xls (36.5 Kb)
СообщениеВариант с UDF
        .Global = True
End Function
Автор - krosav4ig
Дата добавления - 02.02.2018 в 15:03
krosav4ig Дата: Пятница, 02.02.2018, 15:33 | Сообщение № 1531 | Тема: как правильно отсортировать товар по дате поступления??
Репутация: 997 ±
Упс, одна строчка не туда затесалась
Sub ertert()
Dim wsh As Worksheet, dt As Date, x, y(), i&, k&
dt = Range("A1").Value
Range("A1").CurrentRegion.Offset(1).ClearContents
For Each wsh In ThisWorkbook.Sheets
    If Not wsh Is ActiveSheet Then
        x = wsh.Range("I1").CurrentRegion.Value
        If Not IsEmpty(x) Then
            k = 0
            ReDim y(1 To UBound(x), 1 To 5)
            For i = 1 To UBound(x) Step 2
                If x(i, 1) = dt Then
                    k = k + 1
                    y(k, 1) = dt
                    y(k, 2) = x(i + 1, 1)
                    y(k, 3) = x(i, 2)
                    y(k, 4) = x(i + 1, 2)
                    y(k, 5) = wsh.Name
            Next i
            If k > 0 Then Cells(Rows.Count, 2).End(xlUp)(2, 1).Resize(k, 5).Value = y()
Next wsh
With Range("B1:F" & Cells(Rows.Count, 2).End(xlUp).Row)
    .Sort Key1:=.Cells(1, 1), Order1:=xlAscending, _
          Key2:=.Cells(1, 2), Order2:=xlAscending, Header:=xlYes
СообщениеУпс, одна строчка не туда затесалась
Sub ertert()
            k = 0
                    k = k + 1
                    y(k, 1) = dt
                    y(k, 3) = x(i, 2)
                    y(k, 5) = wsh.Name
            Next i
Next wsh
Автор - krosav4ig
Дата добавления - 02.02.2018 в 15:33
krosav4ig Дата: Понедельник, 05.02.2018, 13:11 | Сообщение № 1532 | Тема: как правильно отсортировать товар по дате поступления??
Репутация: 997 ±
Option Explicit
Sub ertert()
Intersect(ActiveSheet.UsedRange.Offset(1), [B:F]).ClearContents
            k = 0
                    k = k + 1
                    y(k, 1) = dt
                    y(k, 3) = x(i, 2)
                    y(k, 5) = wsh.Name
            Next i
Next wsh
Option Explicit
Sub ertert()
            k = 0
                    k = k + 1
                    y(k, 1) = dt
                    y(k, 3) = x(i, 2)
                    y(k, 5) = wsh.Name
            Next i
Next wsh
Автор - krosav4ig
Дата добавления - 05.02.2018 в 13:11
krosav4ig Дата: Вторник, 06.02.2018, 18:10 | Сообщение № 1533 | Тема: Расчет рабочего времени(режим 12х7) между двумя датами
Репутация: 997 ±
Проверяйте.
=(МУМНОЖ(ОТБР(A2:B2);{-1:1})*12-МУМНОЖ(-ТЕКСТ(ТЕКСТ(ОСТАТ(A2:B2;1)*24;"[>20]2\0");"[<8]8");{-1:1}))/24
или с массивным вводом формулы (Ctrl+Shift+Enter)
=((ОТБР(B2)-ОТБР(A2))*12-СУММ(ТЕКСТ(ТЕКСТ(ОСТАТ(A2:B2;1)*24;"[>20]2\0");"[<8]8")*{1;-1}))/24
К сообщению приложен файл: 8522951.xlsx (9.6 Kb)
Сообщение отредактировал krosav4ig - Среда, 07.02.2018, 17:12
Проверяйте.
Автор - krosav4ig
Дата добавления - 06.02.2018 в 18:10
krosav4ig Дата: Среда, 07.02.2018, 16:59 | Сообщение № 1534 | Тема: Экспорт XML в кодировке windows-1251
Репутация: 997 ±
Добрый день. Можно попробовать такой костыль.
Sub ExportToXML()
    Dim strPath As String, sTmp As String
    strPath = ThisWorkbook.Path & "\счет.xml"
    ThisWorkbook.XmlMaps("Файл_карта").Export URL:=strPath
    DoEvents
    With CreateObject("ADODB.Stream")
        .Type = 2: .Charset = "utf-8"
        .Open: .LoadFromFile strPath: sTmp = .ReadText: .Close
        .Charset = "windows-1251": sTmp = Replace(sTmp, "UTF-8", "windows-1251")
        .Open: .WriteText sTmp: .SaveToFile strPath, 2: .Close
СообщениеДобрый день. Можно попробовать такой костыль.
Sub ExportToXML()
    DoEvents
Автор - krosav4ig
Дата добавления - 07.02.2018 в 16:59
krosav4ig Дата: Пятница, 09.02.2018, 13:56 | Сообщение № 1535 | Тема: EAN 8 в excel
Репутация: 997 ±
формула из фала EAN_8_with_chart.xlsx по ссылке из моего поста
=ОСТАТ(10-ОСТАТ(СУММ(--ПСТР(A1;{2;4;6};1);ПСТР(A1;{1;3;5;7};1)*3);10);10)
Сообщениеформула из фала EAN_8_with_chart.xlsx по ссылке из моего поста
Автор - krosav4ig
Дата добавления - 09.02.2018 в 13:56
krosav4ig Дата: Воскресенье, 11.02.2018, 06:11 | Сообщение № 1536 | Тема: Расчет остатков жидкости в цистерне
Репутация: 997 ±
если цистерну можно представить, как пересечение нескольких фигур (цилиндр и сфера, например), то можно и вот так поизвращаться
Сообщениеесли цистерну можно представить, как пересечение нескольких фигур (цилиндр и сфера, например), то можно и вот так поизвращаться
Автор - krosav4ig
Дата добавления - 11.02.2018 в 06:11
krosav4ig Дата: Вторник, 13.02.2018, 17:40 | Сообщение № 1537 | Тема: Выборка повторяющихся значений из базы данных Эксель
Репутация: 997 ±
Сводная, построенная через мастер сводных таблиц и диаграмм
К сообщению приложен файл: _TEST_EW-3-.zip (98.7 Kb)
СообщениеСводная, построенная через мастер сводных таблиц и диаграмм
Автор - krosav4ig
Дата добавления - 13.02.2018 в 17:40
krosav4ig Дата: Вторник, 13.02.2018, 18:45 | Сообщение № 1538 | Тема: Как сделать автоматическую нумерацию таблицы?
Репутация: 997 ±
kvest, а если потом нужно таблицу скопировать, например, в другую книгу на Лист2 в С7? deal
=СТРОКА()-СТРОКА([#Заголовки])
Сообщение отредактировал krosav4ig - Вторник, 13.02.2018, 18:45
Сообщениеkvest, а если потом нужно таблицу скопировать, например, в другую книгу на Лист2 в С7? deal
Автор - krosav4ig
Дата добавления - 13.02.2018 в 18:45
krosav4ig Дата: Вторник, 13.02.2018, 20:34 | Сообщение № 1539 | Тема: Конкатенация и суммирование ячеек по циклу
Репутация: 997 ±
Здравствуйте
Как-то так
Sub sdf()
    Dim Dic As Object
    Dim sh As Worksheet
    Dim r As Range, w As Range, c As Range
    Dim arr() As Variant, arr1 As Variant
    Dim i, j, k, l, m, n, o
    Set Dic = CreateObject("scripting.dictionary")
    For Each w In Sheets("Criteria").Cells.SpecialCells(xlCellTypeConstants, 1).Areas
        With w.Offset(-1, -1).Resize(1, 1)
            n = Abs(Mid(.Value, InStrRev(.Value, "(")))
        For Each c In w.Offset(, -1)
            Dic(n & "_" & c) = c.Offset(, 1)
    With Sheets("Result(было)")
        m = .UsedRange.Columns.Count
        n = .Columns(1).SpecialCells(xlCellTypeConstants, 23).Areas.Count
        Set r = .[A1].CurrentRegion
        ReDim arr(1 To n * m, 1 To 6)
        For i = 1 To n
            For j = 1 To m
                o = (i - 1) * m + j
                If Not IsEmpty(r(1, j)) Then
                    For k = 1 To 3
                       arr(o, k) = r(k, j)
                    l = 0
                    For k = 4 To r.Rows.Count
                        l = l + Dic(arr(o, 2) & "_" & r(k, j))
                    If l Then arr(o, 5) = l
                    s = ""
                    On Error Resume Next
                    With r.Columns(j)
                        arr1 = Intersect(.Offset(3), .Cells).SpecialCells(xlCellTypeConstants, 23)
                        If IsArray(arr1) Then
                            s = Join(Application.Transpose(arr1), "_")
                        ElseIf Not IsEmpty(arr1) Then
                            s = arr1
                        Erase arr1
                    arr(o, 6) = s
            Set r = r.End(xlDown).End(xlDown).CurrentRegion
            n = n + 1
    Application.ScreenUpdating = 0: Application.EnableEvents = 0
    With Sheets("+++++").UsedRange
        Intersect(.Offset(1), .Cells).Clear
        .Cells(4, 1).Resize(o, 6).Value = arr
    Application.ScreenUpdating = 1: Application.EnableEvents = 1
    Set Dic = Nothing
    Set r = Nothing
    Set w = Nothing
    Set c = Nothing
    Erase arr
К сообщению приложен файл: 9251001.xlsm (29.0 Kb)
Сообщение отредактировал krosav4ig - Вторник, 13.02.2018, 20:34
Как-то так
Sub sdf()
    Dim Dic As Object
    Dim sh As Worksheet
        For i = 1 To n
            For j = 1 To m
                o = (i - 1) * m + j
                    For k = 1 To 3
                       arr(o, k) = r(k, j)
                    l = 0
                    s = ""
                    With r.Columns(j)
                            s = arr1
                        Erase arr1
                    arr(o, 6) = s
            n = n + 1
    Set Dic = Nothing
    Set r = Nothing
    Set w = Nothing
    Set c = Nothing
    Erase arr
Автор - krosav4ig
Дата добавления - 13.02.2018 в 20:34
krosav4ig Дата: Четверг, 15.02.2018, 02:25 | Сообщение № 1540 | Тема: Сумма в формуле с динамическим диапазоном
Репутация: 997 ±
"=Sum(G8:G5000)"
"G8:G" & lr
Ни на какие мысли не наталкивает?
"=Sum(G8:G5000)"
"G8:G" & lr
Автор - krosav4ig
Дата добавления - 15.02.2018 в 02:25
